@Richard
  • @Richard
    I need the flexible rubber section for the air intake system and a Rad shroud.
    If you can help Sir.
    3.0 2nd gen
    Brian
    I am looking about getting another 3.0l at the mo so if i get it then i will let you know.Justbrad should have the bits now if you need them asap
      Thanks mate, Justbard if you read this, can you supply?
      Brian
        I think I have the shroud, the intake pipe I have has got a bit of tape around it, I assume because it has a split in it although if it's better than what you've got your welcome to it..
        How quick do you need the bits?
        You can contact me at justbrad@hotmail.co.uk if you want
        If at first you don't succeed.........give up.
          Thanks mate email sent
          Brian
            Did Brad manage to sort the parts out for you as i now have the 3.0l in ready to start breaking
              Still looking for the rubber hose that connects to hard pipe top of engine
              Brian
                I sent the rad cover but I didn't have an intake hose Rich.
                Was the Surf ok?
                  The one on this truck looks ok but i will double check it tomorrow for you and let you know
                    Was the Surf ok?
                    the front bumper is shot but apart from that Brad the condition is ok.I will start the strip down this week.
                      Hi Yoshie.The 3.0l convoluted hose is ok.Is £12 delivered ok with you
                        I have a nearly new OEM intake hose from a 2.4 here, are they the same as the 3.0?
                          They are slightly different Vince.The 2.4 is a smaller diameter than the 3.0.If it was a silicon hose then it would be ok
                          Plus the 2.4 ones have a slight bend in them aswell
