3rd Gen vs Colorado
  • 3rd Gen vs Colorado
    So the 3rd gen is chassis-wise the same as a Landcruiser Colorado, yes?
    Do any of the folk on here with experience of both know of any other mechanical / technical differences?
    Matt (24/7) I'm looking at you mate.
    as you have allready said andy.same chassis running gear just a different body.so any technical difficulties would be the same as a 3rd gen.just not as many toys inside as the 3rd gen.
    www.overfab.uk
      Yeah, just thinking of Matt's truck. Taller load space could be useful when it comes to fitting a drawer pack... Used prices are similar.
        you could always go for the prado.
        www.overfab.uk
          By Colorado, I meant them too. From what small amount of research I've done so far, you seem to pay a premium to get that stupid little mirror on the passenger side wing.
            When I was looking, LC Colorados seemed to be about 30-40% more expensive than comparable Surfs - which is why I went for the Gen 3 Surf.
              main differences are:
              the UK colorado gets a rear-difflock (Prado has LSD rear diff)
              Colorado is full-time 4wd (NO 2wd option), with centre difflock and low range
              3rd Gen-surf, has 2wd option, as well as 4wd, and centre difflock and lowrange
              Sub. Forester
                Thanks for that Andy. That rear difflock would be a very big plus point. Is that ALL UK ones?
                I'd rather have an automatic, seems to be 50/50 split on the UK models. I take it the gearbox spec doesn't change the rest of the drivetrain spec?
                  ...and the Colorado gets rear disc-brakes (not sure if 3rd gen has rear disc brakes, my old 2nd gen didnt)
                  Sub. Forester
                    yes - All UK models have a rear-difflock... but, you need to check it still works,
                    mine did when i bought it, but then failed, when i used it to get unstuck in snow and it stayed locked-on,
                    the accuator then fell apart when i took it off to disengage manually, some of the alu casing had rotted
                    i fitted a new one for about £380....
                    I have automatic, driveline spec is same as a manual
                    a great drive, and same engine as 3rd gen/2nd gen - 1KZT-E
                    the shorties (SWB) only come as manual's
                    Sub. Forester
                      Any experience of the 3.4 petrol engines? Relative running costs and reliability-wise?
                        haven't heard much about the petrol engines
                        and rarely any mentions of them on:
                        http://www.landcruiserclub.net/forum/index.php
                        and
                        http://www.tlocuk.co.uk/forums/
                        the sites i reside on more these days
                        however, pradopoint has a dedicated page for petrol users of the 90-series (colorado/prado):
                        http://www.pradopoint.com/viewforum.php?f=15
                        which has a fair number of points
                        Sub. Forester
                          i got both a 3rd gen surf and the wife has a prado. i'd take the 3rd gen over the prado anyday. don't get me wrong the prado is nice and all that but i find that A) the ride in the surf is smoother, B) the prado is underpowered even with the intercooler.
                            Strange - given they have the same suspension setup and engine!
                            maybe they have different (non-factory) shocks/springs
                            Sub. Forester
                              The Colorado/Prado is likely to be more capable off road, has better brakes and more load space (If you don't have the 7 seats) BUT ...
                              the 3rd Gen looks a million times better !
