Engine swap, But not of the Bushwacker kind
  • Engine swap, But not of the Bushwacker kind
    Landcruiser questions?
    Hi all,
    would anyone know is it possible to fit the 3.0 litre hilux surf engine go into my 2.4 70 series ?
    just a question asked by one of the guys on the leinster4x4 site....
    Linky
    Bob as general given, if you have the imagination and the skill you can fit almost any lump into any truck.
    Here is a v8 quadcam in a zuki sj, if you have seen an sj in the flesh you will understand how impressive this is.
    Brian
      yep its possible,you will also need the complete wiring harness,the ecu and other associated parts.your propably better off getting the complete surf because you may need to use a manual g/box and transfer case and surf u/js to couple up to the 70 series axles.unless you can fabricate a bell housing.
      www.overfab.uk
