@Bushwhacker
  • @Bushwhacker
    hi Vince do you have a lexus speed sensor 1 going spare i could have as wanting to see if can either put in the TC or merge the surf and lexus speed sensor so can get the speedo to work properly need the 20 pulses per rev to get the speedo working properly
    thanks!
    I have a few here, I'll post one off in the morning. Same address as last time?
      yes that will be great thanks i will paypal P+P if you tell us how much it is
        hi vince did you manage to post the sensor off? how much do you want for P+P?
        RE autobox think the oil seal at the back is leaking checked level and it was non existant plus checked speed sensor 2 and it had ATF oil on it!?!
          £2.20.
          febsnowman@talktalk dot net
