Model names
  • Model names
    Hello,
    I wondered if anyone can explain the meaning of "Limited" when used in respect of a model name. ie- SSRX limited.?
    I assumed it was to do with the specification or trim of the vehicle, but I have been told that is is to do with the vehicle having a limited slip differential.
    Can anyone enlighten me.
    Cheers.
    im pretty sure its just the spec for trim etc not the slip diff.
    someone else will probably answer more accurately in a mo.
    My Surf eats knuckles for breakfast!
      Your chassis vin number will tell you if you've got a LSD if the diff number ends in 45.
      peace
      cal
      www.thecellardwellers.co.uk
        http://www.monthofsaturdays.net/surf...sked_Questions
        Might be of help (just for a bit of info) and what Calos said
          I think if it ends in 4 its open and 5 if it's lsd and I think that the "Limited" is just trim level.
          Could be wrong though, my 3.0 has open diff and a 4, with it on the ramp at the moment the wheels spin opposite ways.
            Thats correct, what makes you think you might be wrong?
              That's right, if I jack up my rear axle and turn a wheel they both turn in the same direction.
              peace
              cal
                I meant wrong about "Limited" being a trim level
                  No, you're right there too. 'Limited' to a few million worldwide. You can tell by taking a look on eBay at all the "this is the rare 'limited' edition"
                    I had an LSD in my SSRG. Had to boot it to get the diff to grip the wheel with grip when I got stuck in the mud. I did a bit of research and the LSDs are okay for general use.
                    Oh Nana, what's my name?
