help to I.D.dead surf?
  • help to I.D.dead surf?
    found a surf in my local scrapy, the eng. g/box is out, so when i lifted bonnet there was rad with twin electric fans-horizontally mounted with all factory brackets.couldnt trace any pipes cos they,d been chopped but think it might be air-con cooler? its buried under two other cars but its a black ssrx with sun roof &rear wheel carrier. any of you wise old sages outhere any ideas?
    ps. great forum thanx guys
    i started off with nothing - and ive still got most of it left!
    I have lots of ideas, but not one about your enquiry...what is it your wanting .
    Non intercooled nothing.
      sounds like an early 2nd gen my old g reg 2.4 had the aircon unit mounted like that. Later models had the air con rad underslung
      My 4x4
      My choice
      Back off
        i recon that would make a great ATF cooler?
          Much too big. The cooler only needs to be a third of the size of that radiator.
          If you over cool the ATF, the transmission won't work correctly.
          From memory the ATF's normal operating temp is around 220 degrees.
