@ Sparks
  • @ Sparks
    What day you coming up and what truck you bringing?
    Brian
    not sure and not sure
    probably in Surf and on Saturday
    私のホバークラフト は鰻が一杯です。
      He has work for you, careful!
      Alan
        I know, he's warned me
        私のホバークラフト は鰻が一杯です。
          what is it ?, so i bring the correct tools/ materials
          私のホバークラフト は鰻が一杯です。
            Wall light, but I think I can handle it.
            Jimny broke I take it?
            Brian
              Jimny - nothing I cant handle, just lots of fixes and not much time.
              Rear wheel bearing
              steering stabiliser
              4wd sliding collar ( I think)
              trailing arm bushes
              brakes - may be linked to rear wheel bearing leaking diff oil
              getting started tomorrow
              私のホバークラフト は鰻が一杯です。
                Rear wheel bearing
                steering stabiliser
                trailing arm bushes
                Jeeze man you have 2 full days before you leave. Get the finger out.
                Brian
                  Rear wheel bearing
                  steering stabiliser
                  trailing arm bushes
                  LOL well you did throw it round Bala quite hard, did f3kin well though Gor!
                  peace
                  cal
                  www.thecellardwellers.co.uk
                    2 days, you'll have time left to give it a good clean and polish!
                    Alan
                      It will be washed before cage goes back on
                      Still need to swap the clutch mind. So get your scrap running tomorrow and come give me a hand
                      Brian
                        I was talking to Gordon.....
                        but while we are here, you building a 'shiny' ?
                        Alan
                          brum brum
                            Originally posted by an1mal_69 View Post
                            Was that the carpark entrance?
                            Brian
                              Nice vid Nik, hadn't seen that one yet. cool
                              update:
                              * rear trailing arms off and prepared, bushings removed, and ordered from Suzuki
                              * rear shaft removed, bearing retainer ring off, I have new bearing kit
                              * front hub off, 4WD not engaging .................
                              ran out of time
                              "need new shoes definitely and maybe pads, will purchase tomorrow
                              going to see man with press on Friday and new bushes should be here
                              crossed fingers
                              私のホバークラフト は鰻が一杯です。
