Spent this afternoon fitting the auto locking diff. First drive all is well. You can feel there is something different. Installation was just time consuming and fiddly - The 3rd member is damn heavy!! To re-fit it was the case of "if you dont get in now you aint ever getting in!"
I went to go and get the truck washed as we went to some lanes last night. When I backed off the throttle I could hear this loud RATTLE. I wasnt sure if there was something not bolted up right with the front diff or I had messed up with the rear. I now think that there was may be not enough oil around the diff. After I drove a bit longer the noise completely went and has not come back since.
I went into ASDA car park (its closed now) and left two nice rubber trails around the back.
You have to keep the throttle steady when cornering so the diff doesnt lock. But, even when the diff does lock and my 33"s on it doesnt force the truck forward or anything, you can just hear the inside tyre slipping slightly.
PS. The diff drain plug on the axle is a 24mm !!!!! :/
Look forward to trying it out on some lanes soon. I needed the diff last night - the stiff suspension often lifts the truck up off the floor. You bounce down the rut and then bounce right back up out of it
