coolant temperature sensor location
  • #16
    the inner wing has to go then
    aye it looks like the inner wing has to go then .can always fabricate a plate to cover the hole.
    • #17
      No! just two vertical cuts with a thin disk in an
      angle grinder about 6" long and fold them out.
      becarefull of the 2 rear heater pipes at the bottom.
      then lift the wiring harness out of the way from above
      to expose the little bugga. here's a piccy for ya.
      Hope this helps.
      Gman.
      If it aint broke, keep goin' till it is.
      • #18
        Maybe drop the starter motor out and then replace the sensor
        • #19
          Hi mate,
          It took me 4 hours to get the starter out, thats why
          I cut the inner wing!!
          Gman.
          • #20
            Sensor connector hooped
            Grassman...in searching for a possible repair solution to my problem, I noticed from a picture you had posted that you had the same problem as I have. The connnector to the sensor has one of the wires broken off right at the connector itself. How did you repair this? There is no wire available at the connector to splice in a new piece of wire. Does the connector itself have to be replaced? If so where could I order one from? Any help would be appreciated.
            1991 Hilux Surf 2.4td
            2.5" exhaust, Cherry Bomb muffler
            Custom winch bumper, Warn 9500HS
            Boost Controller running 13lbs
            Dual Optima Red Tops
            K&N Air Filter
            • #21
              that one looks a little different to mine, mine has a plug on it,
              • #22
                Hi mate,
                I ordered a sensor from a breaker on here and the connector
                came with it, so I just cut the wires and reconnected them,
                and presto!! it worked, it was the broken wire not the sensor,
                There are some breakers of trucks on here, have a look round
                the parts for sale, or try stormfoce he's good.
                Hope this helps.
                Gman.
                • #23
                  Breaker parts
                  Thanks for your reply Grassman. We don't have nearly the same amount of these trucks running around the countryside here on the other side of the pond. Therefore...it can be difficult trying to find the parts when needed. I was thinking that that sensor and the associated connector might just be a generic Toyota sensor...and may be able to find one here on a 4Runner or Corolla or something like that.
                  K&N Air Filter
                  • #24
                    Hi Runner,
                    I don't know about generic, it's possible I suppose.
                    Why not ask Stormforce on here he might have the
                    parts you require, Start a new thread with @ Stormy
                    and ask him, you never know.
                    Hope this helps.
                    Gman.
                    • #25
                      Just search Google for 89422-35010 and you should find somewhere over there to get an aftermarket one or even the genuine.
                      Nev
                      Edit: Heres one place in the US.
                      http://www.lexuspartsnow.com/parts/l...422-35010.html
