mudskipper
  • mudskipper
    Hi John.The gearbox strut and bashplate have been sent as with the bodylift so you should have them tomorrow
    I had to cut a bolt off of the g/box strut so you may see some small grinding marks but its only surface
    I finish work at around 17:30 tomorrow, so flask bacon butties and some lights john? hehe hope you;ve been spraying the body bolts with some WD40 oO
    peace
    cal
    www.thecellardwellers.co.uk
      if you jack under the gearbox to take the weight then i took out the 4 10 or 12mm bolts from under the g/box mount and then took out the 4 17mm bolts either side bolting it to the chasis.As long as the bolts come out ok then 30 mins and it will be done.It took me about 20 mins to take this one off as i had to cut a bolt off first
        brilliant Rich
        guess it will take longer for me to get mine off as its somewhat battered
        thats my evening sorted then
        cheers again
        Cal see you tomorrow evening then
          I'll bring me jack along lol
          peace
          cal
            did you get the parts fitted ok John
              Rich
              cheers mate they came last night, and i fitted the lift kit tonight, the cross member will get done over the weekend, only thing is i was hopeing that you had included the gearbox rubber mount as mine has come adrift, but hopefully i will be able glue it back on.
              a big thank you to mikethecamera for all his help=2.5 hours to lift a surf, without you i would be still at it
              thank you Cal for the hand in fitting the winch mount and winch
              cheers guys
                piiiiiiiiiiics..
                  not till its all done
                    A pleasure sir !
                    Just needs a little more felling couple of plates and we're cooking
                    sneak peek..hehe
                    Sorry about the finger btw, my is starting to smart a little after that hot bolt, hehe can't believe I picked that up still lol
                    peace
                    cal
                      No problem 118
                      No matter how bad it gets, if you're still alive it's just another bad day.
                        Originally posted by Mikethecamera View Post
                        No problem 118
                        thanks 118
                          is this 118 118 or 118 247 or 118 maureen
                            Answer your question?
