check
  • check
    1 x surf, with no engine in it.....check.
    1 x lexus ls400 WITH an engine in it....check.
    1 x shoppin list supplied by vince.....check.
    1 x radiator just bought from rich....check.
    1 x body lift coming from evildwarf....check.
    WAHOOOOOOOOOOOOOOOOOO......... ......IVE GOT ALL THE INGREDIENTS FOR A GODDAMM LEXURF.
    a little bit of wee just came out.
    Non intercooled nothing.
    http://www.youtube.com/watch?v=Hi-Gs...eature=related
      always wanted to do this but i never have the time how much would it cost if i could just let someone do it for me ????
        VINCE !
        There's a CUSTOMER !!!
        I think it was £2k the last time Vince did one but it may have gone up by now ...
          Gwh is getting the shakes jumping up and down like a school boy
          Rich said that he would pick up the body lift when he brings the big wheels over to me he has a truck to pick up and then he is dropping in to vince you can almost taste the lexurf i bet
          I NEEED MUD.....and Welsh spring water!!!
            cheers andy. i put the cash for it in his bank yesterday. and yup....lexurf is coming......
              Lucky bugger.
              Give me a shout when you get it, would love to see it, am guesing my bank balance might take a bashing shortly there after .
              Neal
                That's great news - I've been waiting for a hairdresser to volunteer to be Vince's guineapig !
                And if it works all I need to do is prise £2k out of the purse holder ...
                  There's just one more item to get Graham, an after market temp gauge of your choosing, and where you would like it sited.
                  A pod on the dash?
                  'A' pillar?
                  on the steering column shroud in front of instrument cluster?
                    A pod on the dash?
                    'A' pillar?
                    I find myself asking " what would vince buy, and where would he put it"......
                      'A' pillar, relativley out of the way but still easy to view.
                      http://prosportgauges.com/52mm_digit...es_gauges.aspx
                      Just an idea.
                      Neal
                        I've found something I like on CBS. There is a nice black faced dial. It can also be lit up with several different colours...pretty.
                        I'm not to keen on the idea of a pillar mounted gauge. I'm such a fat git, I'm always swinging off the handle to get in and out. I like this one I've found as it's much more accurate than the surfs, but not to 1/10th of a degree or something equally distracting. It's pod mounted, so a little shaving of the base, should see it fitting nicely on the dash.
                          You'll like these then......
                          http://www.rspec.co.uk/index.php?mai...=index&cPath=3
                          I have a temp and oil pressure gauge from the Smoked super white range, mainly because they match the Lexus instrument cluster, Black when off, white illumination when ignition on.
                          One cool feature of these gauges, they do a full sweep and go back to zero (or whatever they were reading when the engine was switched off)when the ignition is switched on.
                          They do gauges with programmable warning buzzer/light too, have a browse.
                          p.s. 52mm is the popular/usual size.
                          Similar gauges here.....
                          http://www.youtube.com/watch?v=SVoaD...ext=1&index=39
                            Ooohhh...I do like those...a lot!
                            Will they both got in a double standard sized pod...I can't find them on that site?
                            Edit: found them. Some real nice black plastic, with a chrome bezel.
                              These?
                              http://www.rspec.co.uk/index.php?mai...x&cPath=92_120
