which oil?
  • which oil?
    Hi,
    Can anyone reccomend a good oil for the LSD diff and the front diff on my KZN185
    cheers
    stu
    If yer ma comes fae Buckie yi must be unlucky!
    Front diff Hypoid gear oil 80W/90 2.8 litres
    LSD diff, Im sure you were given this in an earlier thread, but
    Recommendation is Castrol HYPOY90 LS oil, but I used comma Limited Slip diff oil, which Im sure will be just fine. Lets face it, its an old truck, its long out of guarantee, the LSD is most likely past its best and even when perfect isnt hugely useful. I dont feel that I did anything terrible by using the comma product, which you will find at any motor factor for about 4 pounds per litre bottle and which Im sure matches perfectly the spec required.
    Bogus
    and apart from it being a bit of hole with record levels of drunkeness, crime and violence ( as per the Northern Scot weekly crime section and as per Monday editions of the P&J) Fits adee wi Buckie??
    Сви можемо
      Comma it is.
      Cheers Bogus
