Rear Wiper Blade
  • Rear Wiper Blade
    Hello Surfers,
    What rear wiper blade do you guys fit to your surf's?
    I got a set of 3 flat blades from e-gay, the front 2 fit ok.
    I've only just got a rear wiper arm, but the flat blade
    does not fit the arm. It looks like you need a hole at the top
    of the blade to screw it onto the wiper arm?
    Thanks for any help, Stuart.
    the blade on the back of my 2nd gen has 2 screws holding it onto the arm, i usually get this wiper from a motor factor, it was the same story on my old starlet
      Thanks BigBobE, I've got a Milehams car shop close by.
      I will take the surf up and see if they can help.
        I get mine from milners, genuine toyota part for £8 whereas toyota dealership wanted £20. If you've not got it already, then you'll need a locator that attaches to the arm and the wiper. It's this thing: http://www.roughtrax4x4.com/?doc=16&cid=618&vid=1288
          I've removed my rear wiper, and the motor/mechanism, bluddie useless gimmick.
          Whats behind me on the road is not important!
