Hi there folks,
I will be fitting new glow plugs to the Surf shortly (LN130 2.4TD) and according to the Roughtrax website they are 11V, but that you should check to see before ordering. It says that this can be seen in situ cos 11V should be stamped on the glow plugs but I'm bu66ered if I can see anything stamped on them!
Have I missed the obvious? Are there any different glowplugs that I might need to fit apart from the 11V Roughtrax ones?
Any info appreciated!
