Hi guys
I hope some of you remember me - i used to have a surf then had to sell due to rocketing fuel prices....the bought a saab...then regretted it...then bought a Landcruiser colorado...now skint from even higher fuel prices lol
I have a question - i know it's a bit cheeky as it's not a surf but it is the same engine etc and you lot sure know your stuff so am hoping someone can help me out
A couple of months ago while driving along at about 55 the LC started to vibrate really badly and wouldn't go into 4th gear - i pulled over then started off again and it was fine
Since then, now and again, it either refuses to go into 4th or the overdrive seems to turn off so i only have 3 gears and it changes at 3000 revs
Occassionally the AT/P light came on when i stopped and put it in park (telling me the engine brake couldn't be applied as the 4x4 box was in neutral although it wasn't)
Had the gearbox and transfer box oil changed and the neutral switch on the transfer box cleaned as it was mentioned that if the switch was dodgy it could send a fault to the ecu and the car would go into limp mode (hence the O/D coming off)
It is still doing it once a week or so and sometimes i can be driving and it drops out of 4th into 3rd and the revs shoot up but then 10 seconds later it goes back into 4th again
My local garage have no clue - spoke to Toyota today and they have no clue either although they say it is not gearbox or it would do it all the time - possibly an electrical problem but would have to strip it out and i cannot afford to remortgage my house for them to do it!
I have had it plugged in and only a fault on the idle speed control valve showed up and there is no diagnostic on the gearbox
Any ideas?
Amanda
Any ideas?
Amanda
