4-runner higher then Surf?
  • 4-runner higher then Surf?
    we went out for a bit of a treck last night, while parked up in KFC we had a look arround my 4-runner and mates surf, 4 runner looks about an inch higher then the surf? can onyone clarify on this? (Standard)
    3.0L V6 Manual 4-Runner
    .:one::.
    Big Sound System (100 Infinity 6x9's Boxed :: 2 JBL GTO 14" 255w Subs)
    Bull Bars (Slightly Customized)
    .::To Do::.
    Tires MT 33's
    Snorkle
    4" Lift
    Tow Bar
    Wind Deflectors
    Spoiler (Front & Back)
    the rear springs on his truck may be knackered or your truck may have newer springs or lifted a bit before you got it
    Measure from the lip of the wheel to the underside of the wheel arch and it should be about 13.5"
      Everytime stormforce!
      could you clarify on the landcruiser lift option
      heard alot about springs sagging?
      .:one::.
      .::To Do::.
      Tires MT 33's
      Snorkle
      4" Lift
      Tow Bar
      Wind Deflectors
        You can buy the landcruiser springs from www.milneroffroad.com they are the hd j80 springs which i think is the import one.
        Then fit the plus 3-4" shocks TonyN will be able to give advice of the best place to buy
        Extended braided brake lines from roughtrax
        either adjustable panhard rod or get panhard drop bracket.
        Free wheeling hubs to save wear on front cv joints
        2" ball joint spacers from Surfenstein and then crank torsion bars up an inch to level the truck.You may want diff spacers aswell but that comes down to the individual with those.
        2" body lift and then you got a 5" total lift
        The lancruiser springs will give the surf an instant 3-4" suspension lift.
        If you want to have a chat then you can always give me a ring on 07974183876
          Bearmach are stockists for Pro Comps. I ordered a set for friends Landcruiser a few months ago.
          www.scottishmudclub.com for scottish events
            you got any contact details for this company Smiffy as i think there will be quite a few people interested to know of a supplier
              awsome might give you a call later,
              just putting my list of parts together, Freewheeling hubs at 55 quid each :S ouch!
              .:one::.
              .::To Do::.
              Tires MT 33's
              Snorkle
              4" Lift
              Tow Bar
              Wind Deflectors
                they are worth it in the long run tho as they will save you a fortune
                  i only need to do the front wheels?
                  .:one::.
                  .::To Do::.
                  Tires MT 33's
                  Snorkle
                  4" Lift
                  Tow Bar
                  Wind Deflectors
                    Here Stormy http://www.bearmach.com/ . They are very helpfull. They did mostly landrover stuff before but have extended their range to all vehicles as far as shockers go.
                      just on the front with fwhubs
                        cheers mate
                          cheers mate
                          No probs.
                          Think for 2 standard shocks (es9000's), with boots,delivered was just under 90 quid.
