today i did abit of tinkering with the surf,
first things was fix the radio as the reception was poo and the electric ariel motor was'nt working ( stuck up anyway but thinkings about the future if i replace it
) so found the power to the ariel was off so fixed that and the pin in the ariel addaptor had snapped so just got rid of that and used the trusty spade connectors. and its now spot on
then i desided to put the lower half of my bumper back on which involed removing my a bar undid 2 bolts and on the 3rd bolt (tow hook side) i found the nut inside the chassis was turning, so had to grind the head of the bolt off and fish the rest out. must of broke the spot welds when pulling my freind out when off roading, so now i need some ideas on how to get a bolt back in there as its inpossible to get a welder in there to re tack the nut
and also found the rear crank seal is leaking
