Radio install HELP
  • Radio install HELP
    Hi guys
    trying to install radio/CD into my 2.8 non turbo LN131
    now after much grief from halfords got a PC2-17-4 wiring harness
    but when i put it all together the radio dont work
    Question has anyone got a wiring diagram of the LN131 radio wiring PLEASE so i can figure out whats wrong (so i can rewire to make work)
    yours expectantly and Desperate Pops
    Enjoying Life after Cancer
    Pops
    hey i labelled all cables for toyotatony before christmas i still have that file if you want to send me your email address i can forward it...
      Mr
      you got PM thanks
      Pops
        http://www.installdr.com/InstallDocs...PDF/869017.pdf
        Down the bottom of the page, think it's for yours.
        Neal
          pops,why do you think i left it as it was,..........
          www.overfab.uk
            Mr
            because radio's/ fog lights and Horns are not your strong point
            but rip a truck apart cut bits off and add bits your the Best
            now move along i need constuctive help not why i did'nt do its here
            Pops
              i will say one constructive thing martin,and that is i have a feeling that they split the live feed from the fog light switch to power the radio.
              www.overfab.uk
                Mr
                got the fog light working but the switch not illuminating tho there a terminal not connected and when i connect a black wire found lurking in there it blows the fuse
                Pops
                  yea thats coz youve got the other terminals round the wrong way.pull the switch out and find the earth terminal on the switch.the black wire is the earth.the other two are live in and switched live to fog lamp.this is where a multi meter comes in very handybasically,pull all three wire through the dash.put a circuit tester on one wire and the other end on the door hinge,turn the light on to dipped beam as the wire that lights up the circuit tester is your live feed to the switch.then once you have found the live wire,keep the end of the circuit tester on that wire then remove the wire from the door hinge,strike this agains one of the other two wires.the one that lights up the bulb is the earth,then that leaves one wire which has to be the switched live to the fog lamp.simples
                  www.overfab.uk
                    Mr
                    Way ahead of you USED A Meter to check first, still blows fuse think swith could be problem so getting new 1 now
                    Pops
                      ah,hang on have you checked the wire where it comes through the rear floor? it could be chaffing on the body work.????
                      www.overfab.uk
                        Mr
                        yes thats ok checked and re routed wire
                        Pops
                          ok,i'll shut up then.
                          www.overfab.uk
                            Pops.
                            Both surfs I've had, I've run a new live and earth. It was a damm sight easier than trying to trace old(and probably messed around with) wiring.
                            Non intercooled nothing.
                              Mr
                              Dont be like that
                              Pops
