water leak
  • water leak
    hello peeps. just sorted the fuel problem i had out on my 2nd gen 2.4 but when i drove it home i developed a serious water leak .when i looked under the bonnet i noticed the pulley attached to radiator fan was moving sideways when turning and this was where the water was leaking from.has anyone had this problem? if so is it a costly repair?
    if there is movement on the pulley that the fan drives off that is your water pump
      Re
      Sounds like your water pump is fubar!
      Pain in the arse to change on a 2.4
