Boot Dimensions
  • Boot Dimensions
    This may sound bizarre, but I wonder if someone would be so kind as to measure the dimensions (just width and length) of a 2nd gen boot for me. Back seats up and down, the gap between the wheel arches and the width of the space between the bottom of the windows. Doesn't have to be massively accurate, just pondering something.
    Thank you, I love you all.
    36" between the arches.
    53" above the arches.
    44" from the bottom of the rear seat backs to the tailgate.
    It's roughly 6' 4" with the rear seats down, more with the rear seat bases removed.
      Seats down= 173cm
      Seats up= 115cm
      Window panel 2 window panel=133cms
      Wheel arch 2 wheel arch= 97cm
        You are both beautiful, thank you.
        Now to find a pencil and a bit of paper.
          Well, its roughly the same except for the whole length, mines 5ft 8" to the seat bases
            Yeah you're right, I was going from my middle aged memory. I couldn't be arsed to put the seats down, it's -3 out there!!!!
              C'mon vince... I'm on double shifts at present...m&s do decent thermals.
              Non intercooled nothing.
                I've been thinking about some recently.
                  I swear by them, three layer system and your toasty.
                  http://www.abc-of-mountaineering.com...ringsystem.asp
                  But then I think millits is a fashion outlet.
                  peace
                  cal
                  www.thecellardwellers.co.uk
                    Will she fit?
                    Sent from the iPad you "lost"
                      Originally posted by slobodan View Post
                      Will she fit?
                      With the legs cut off and next to her, yes.
                          Adam, 3rd gen are bigger.
                          Brian
