Shaking and knocking
  • Shaking and knocking
    Hello everyone.
    Surf going back to the garage tomorrow, for jobs, see post,, Back to the Garage,, cant get solenoid parts untill Thursday, so looks like a long wait.
    Found another problem today, When braking it seemed to shake and shudder at the front end, and can hear it knocking. only seemed to do it when braking at speed on the moterway.
    Any Ideas??
    Will get them to check it out tomorow.
    Cheers Kevin.
    95, SSRX, TD, AUTO,
    Brakes
    Hi you might have a "CRACKED DISC" had simliar problem on my "Merc"
    Live Life To The Full
      Either that or warped dics (rotors)
      Rich.
        yeah warped disks I had that problem, either skim them or new ones
          Brakes
          Hi warped disc,s would not knock, a cracked one would be catching a brakepad each time it came round.
            Hello. Thanks everyone for your help.
            The garage said its probably brake judder, and the discs will need skimming.
            Surf should be in all week, so will have to wait and see.
            Thanks again, learning loads from this great site.
            Cheers Kevin.
            95, SSRX, TD, AUTO,
              Skimming
              skimmimg blimy a set of discs are only about 30 something quid from milners i had to change mine a while ago i think for the cost id rather put new ones on m8
              black n tan
              black n tan
              yes i am a dobermann man
                sly, mine are warped as well, just been trying to ignore it but it's got worse. How long did it take you and is it an easy job?
                  doddle
                  yea mate took less than an hour lack up front take off wheels undo and take off calipers just swing them out of the way and ya discs just pull off put new ones on calipers back wheels on no more wobble job done under an hour m8
                  black n tan
                  black n tan
                    Dont forget to push the pots back into the calipers your new disc's will be thicker than your old
                      That's wot i like to hear - doddle !
                        Got surf back today, it has to go to a different Garage on Monday to get the discs skimmed while they are still on the car.
                        mechanic says for him to change them it will take him 4 HOURS, to change discs,
                        Are 2 gens, different to thirds, tried to tell him that it should take an hour or so,
                        Anyway will get them skimmed on Monday.
                        Cheers Kevin.
                        95, SSRX, TD, AUTO,
                          Cheers Kevin.
                          Its no doubt taking 4 hours because they're going to skim them on the car, but why they're doing that I don't know, as slydog has pointed out they're not expensive and easy to change. Far more cost effective to simply replace them.
                          Maurice
                            Hello Again, He actually says it will take him 4 hours to replace them,
                            The garage it is going to has a specilist machine that skimms them still on the car, taking so they say 9 minuets each side.
                            Cheers Kevin
                            95, SSRX, TD, AUTO,
