water leek
  • water leek
    hello boys got a prob with my rad on my surf ,i keep loosing water ,the expansion tank is full the rad sum times is ok and the top pipe off the rad is hot but the bottom pipe is cold . allso the expansion tank is ####in water out of the over flow on to my batt tray and the water is very rusty help help
    Take your thermostat out and run it. See if the problems gone.
    私のホバークラフト は鰻が一杯です。
      Need a bit more detail here.
      When you say the expansion tank is full, do you mean all the way to the top? If so, it will push coolant whenever you drive it. It should only be half full and is called an expansion tank for a reason
      What do you mean the rad is sometimes OK? What times and what do you mean by OK? You mean full?
      The bottom hose should be much colder than the top.
        If the expansion bottle is blowing out water then the system is pressurising i would of thought and if so then i would say the head has gone or going
        When the truck is running is the top rad hose soft or hard.If it is hard then i'll go by what i said above
          Some other veg, a few potatoes and some seasoning is better than just water and leeks?
            I was wondering if it was the Welsh water causing these problems?
              hello , yes got it back from the garage b4 . head gone deffo ,all from my boss putting super unleaded in it last week , spoke to stevo at stockport engine co and he gave me the bad news on how much to fix ........ might be goin scrap yard
                What i would do to start with and thats see if the head gasket has blown.I had a 3.0l in a while ago with starting problems.I took the head off and the gasket had blown between 1 & 2 pots but the head on that truck was ok.I would get the head off and get it pressure tested aswell to be on the safe side before spending to much on it and check the gasket also
                We did find out tho that the previous owner had put unleaded in which in turn blew the c rap out the gasket but the head was ok
                  Why would that be Richard? Higher combustion temperature?
                    thats what i was told yea
                      pressure...
                      set fire to some petrol, then try diesel, then imaging the result of the petrol going off under 400psi in your Surfs combustion chamber, instead of 150ish psi of a petrol motor.
                        pressure...
                        Ah. Off to set fire to the petrol station over the road now for comparative purposes...
