Hello
  • Hello
    Hi to all !
    Have just 'inherited' a J reg surf SSG-R, which needs some TLC
    I hope theres some knowledgable folk on here as I have a stack of questions.
    1st one being...........how the hell do I get in the boot! (not opening)
    Cheers,
    Andy
    Hi And welcome.
    Open rear window, lift up little button on inside of tailgate then pull up the larger handle tailgate drops down.
    My 4x4
    My choice
    Back off
      Hi Andy,
      If you use the key in the tailgate to drop the window or with the ignition on use the 'up-down' button on the centre console to drop it, then lift the lock which is slightly left of centre on the gate & then use the handle to the right of it to drop the gate. Good luck & hope it works.
      p.s. make sure the rear wiper is switched off or the window won't open either.
      Took me a little while to figure it out!
      It's only kinky the first time...
        and the window lock button isnt pushed in on the drivers door control bit
          Make sure the rear wiper is seated correctly or the window won't open.Wriggle the wiper arm while using the key to open the window
            Cheers guy's!
            Much appreciated. Will give it a go tonight.
            I can hear something clicking when I turn the key (left and right) in the boot lock, but there's nowt happening.
            Will check the drivers side window lock button.
            The switch by the gearlever for the rear window again, I can hear a clicking in the rear, but no movement.
            Will report back with any progress............fingers crossed.
            Cheers,
            Andy
              Ello and welcome, another N.Wales Surfer!
              Where are you in N.Wales?
              peace
              cal
              www.thecellardwellers.co.uk
                Hi Cal.
                I'm wrexham, you?
                Cheers,
                Andy
                  I'm in Llandudno, pretty sure there a few guys from here in Wrexham too.
                  peace
                  cal
