sad
  • sad
    hi, just thought id say good after noon all, and that me pumps deffo ceased to funtion, gonna cost megga o joy, if i can find a garage here to do it, motor so cool dont wont to scrap it, o well plod on.
    fuel pump, water pump, washer pump??
    it's not the end of the world... if it's the fuel pump, just look for a diesel specialist and they'll probably be able to do something with it!
      sorry injection pump, can get second hand one but garage reckon 8 to 10 hour job, ouch.
        8 to 10 hours is a bit steep.Knock that back to half at least i would of thought.I'll send a pump for £100 and i'm sure there's someone on here close that can give a hand to fit it
          cheers, had a look at how to fit pump wow mega, looks like most of engine has to come out, timeing etc gotta now wot ur doing scary.
            Follow the write-up on how to change the timing belt and do the pump at the same time.
              just aint got the bottle vince, got all diagrams how to do the job just gave me a headache,
                your looking at a hour max to strip everything down and then fit the pump and again say 2hrs max to put everything back and check it all and that should be a garage.
                The pump has 2 bolts on the back to take off and they are the ones fixing it in place and 2 fixing it to the block and then the 1 with the pulley wheel.I cant see how a garage can quote for 10hrs to do it.
                Just put a thread up to ask for help from someone up your way.I should be able to get a pump to you on Tuesday if needed
                  mudskipper had a look, said he will ask a mate not heard from him yet, got number of a little one man garage will try him.
                    even if you get someone to do it for £100 then its only cost £200 to get the truck back on the road and better then 10hrs labour at whatever cost they charge
                      ur right about that, will let you no about the pump you have, cheers
                        I changed my 2.4 pump in three hours. It is a tiny bit fiddly but do-able.
                        Non intercooled nothing.
                          brave man, aint got the tools either, well thats my excuse.
                            Just sockets and spanners .
                              I'd allow 3-4 hours, there's lots take off, and you dont want to rush it. 2 hours is pushing it a little..
