Mate's rates person required in Worcestershire
  • Mate's rates person required in Worcestershire
    If I buy all the goodies is there any one around Worcestershire that is prepared to do an oil change and change the transmission fluid for me? If not, can you recommend a garage that would be prepared to do it if I supply the goodies? It is a 1997 KZN185 engine. Thanks.
    i am sure Apache might help you out as he is in Malvern
      Hopefully he will log on in the near future and let me know whether he can do it or not.
        PM him, you can also get some stickers at the same time..
          mates rates
          I just turn up at my local tyre centre with the parts and £20 last time i went down they supplyed the oil at trans fluid and charged me £30
            hi mate if your struggleing then let me know and i'll change your oils and filters for you, for a coffee and cover my fuel, i'm not to far away from you
            when the sh*t hits the fan greet the reaper with a smile
              Hi Ian. Not a problem, but do you mind waiting until the snow's gone so my ar5e doesn't freeze to the pavement?
              Only takes 20 mins to do the oil / filter, and similar to change the amount of ATF you can get out without going into it in a bit more depth!
              I think you can get about 2 - 3 litres out without using gallons of the stuff to make sure you changed the lot. Not usually necessary to do that though unless your fluid is totally fcuked.
              Get the stuff, and when it warms up a few degrees, we'll arrange a time.
                ........... but do you mind waiting until the snow's gone so my ar5e doesn't freeze to the pavement.......
                ....and when it warms up a few degrees, we'll arrange a time..........
                Pussy....
                  gimp!
