Hi Trev
I've finally dug out my scans of the 3rd Gen dials, took me long enough i know, sorry.
Anyway, they're somewhat on the large size, I'm attaching some jpg versions, they're fairly compressed but should look OK.
If you need higher resolution pics, I have the original scans, but each main dial is nearly 80 megs in its raw state, most of the jpg versions i used run around 700k (the ones i'm posting here are smaller). Drop me a PM with your address and I'll burn the lot onto disc and post them to you if required.
Note also, these pics have been retouched, slightly, colours have been removed, warning symbols which would normally be invisable are shown in white. Speedo is redrawn version with both Mph & Kph as my original was Kph only.
