quick question about crank pulley
  • quick question about crank pulley
    how come the back 2 channels on the crank pulleyare not part of the main pulley but are attached using the rubber insert instead, what purpose does this serve ,
    cheers
    animal
    its the harmonic balencer, stops the crank vibrating itself to bits.
      cheers
      i always wondered
        i have one of the roughtrax one for sale if your after one its the cast one with no rubber to debond
          how much mate
            Have you got a clear pic of this? I still can't believe there is one without the rubber.
            Nev
              I have a Roughtrax one, it is laminated.
                1989 - onwards Diesel 2L/2LT &3L. A new Genuine Toyota front cast pulley from RoughTrax, as per the original fitment has a rubber lining inside the pulley. It is common for this rubber to de-bond causing the 2 pulleys to move back and forth and even wear through the covers or cause a squealing noise. The 2 front pulleys are steel and simply bolt to the front of the new cast pulley. Use woodruff key Si044A if required.
                I rest my case.
                Nev
                  £70 i can drop it round with the intercooler if you like all being well next sat! unless something changes on the V8 front!
                    mine crank pully broke in half
                    yep i went to toyota
                    price is 110 quid plus VAT and a 6 weeks of waiting
                    got mine in 4 weeks tho? dunt no how
                      Nev
                      hi nev bought one for mitsi sport 2.8 one piece alloy worked a treat didnt feel any excess vibration
                        Got a link for these?
                        I can't believe there is a crank pulley (harmonic balancer) for the Surf that is one piece and not have the rubber. The crank will destroy itself without it.
                        Nev
