I got a non related Surf problem . At work we have a towbar mounted gritter machine that has to be available to work 24hrs a day in Winter. I have to maintain this to ensure it works when needed. Just got it ready for this Winters work when the control unit in the cab has gone faulty again . This box of tricks basically allows you to regulate the spead of spreader motor so you can control the throw of the grit. These control boxes keep failing at a cost of £345 a go ! Inside is a tiny circuit board and a couple of relays.
We can not see how this can cost £345 . So today I made a panel up using a 3 speed heater fan switch and the resistor pack out of a Transit van . It worked but the resistor pack got very hot and smoked a lot . It did however give the 3 speeds we wanted .
Question is .... How can I build a better unit then this which has 5 or more speeds and wont smoke due to the load . I recon the rating on the resistor pack I used was about 25 or 30 amp , which is a bit low I think . I would estimate the spreader motor is about 45 or 50 amp draw.
Can anyone help with parts supplier or any advise .
This is quite urgent as temps are to drop next week .
