offset help
  • offset help
    ive found some rather old school wheels that i'm hoping will fit the surf,but i'm terrible at working out the offset,can someone help?
    found an et stamp on the wheels but in inches which is 0.2,also took some other measurements,from the very back face of wheel to the back where it would attach to hub,ie where bolts go thru is 4 inches,and from that spot to outer rim is 5 and three quarter inch,and wheels are 8.5 j,can anyone help?
    They are a negative offset. 5-3/4 minus 4 = 1-3/4 negative if my maths are correct. Odd size though at 8.5. You'd have to fit 12" wide tyres to these I think. Also a JJ type are a better rim as far as I know.
    Nev
      Maybe 7/8" negative offset as you have to halve the figure I stated above........I think. Add 7/8" to 4" and you get 4-7/8' and deduct 7/8" from 5-3/4" and you also get 4-7/8" which is the centreline of the rim. Understand? I hope so, because I've confused myself I think.
      http://www.gtsparkplugs.com/WheelOffsetCalc.html
      Nev
        Nev
        nope,lol will they fit?
          Wouldn't have a clue. What's the PCD (wheel stud Pitch Circle Diameter) of the rims? What tyres do you plan to put on them? The offset sounds ok as it's about -22mm. I wouldn't use rims with a J tyre bead profile though.
          Nev
            Nev
            stud pattern is fine,off a patrol,although from a 1980 one lol,tyres im open to tbh as id have to get all new,why not use j?
              Patrol rims will have a larger centre hole so more pressure will be placed on the studs. The j or jj relates to the rim profile where the tyre bead fits. Remember reading somewhere that the jj is better but can't remember details.
              Nev
                http://www.carbibles.com/tyre_bible_pg2.html
                Nev
                  Nev
                  hmm well i really dont know now then cheers for help tho nev
                    Where's all the tyre/rim experts on here?
                    Nev
                      Nev
                      god knows lol,ah well no worries,cheers for trying
                        Nev
                        gone elsewhere
                          Not helpful Will
                          I'm a custard donut monster
                            Originally posted by pirate-storm View Post
                            gone elsewhere
                            You're wrong Will
                            there's still rim experts around
                              Originally posted by jotto View Post
                              Not helpful Will
                              thats not fair i was just saying but other people can take the #### n get away with it ffs better ban me then aint ya
