Air con gas
  • Air con gas
    hi i had to replace the idle arm,but in doing so had to move the air con over and remove a pipe ,, all the gas came out (***ics). just wondering if it is ok to drive the car without air con or dose it cool something els as well,,,
    ps how do you refill as well
    thanks neil....
    Neil
    It's ok to drive it with no gas, but unfortunately it will cost you about £60 to get it gassed up again.
      thanks neil....
      No problem driving it, this will not affect anything else.
      Refilling is usually a specialist job, try searching the forums as this topic has been covered several times recently.
      Maurice
        Hi,
        I've just replaced the Steering Idler Arm but did not have to disconnect the air con or any part of it although the nuts on the 3 bolts that mount it to the chassis are very difficult to get at but it can be done having said that the bolts were very tight and I had a mate with an Air gun release the bolts First just using a spanner even a quality one was very difficult !!!
        I'd Rather Have A 4" Lift Than A 4" Extension !!!
          don't know if it's the same gas, but when my mate was de frosting the fridge with a hammer and chisel, he got a face full of gas when the side wall of the fridge was punctured!... made him feel a little queezy for a while!
