grand cherokee has lost reverse.......
    Originally posted by BioHazard View Post
    But it's not mine
    It probably just saw you and crapped itself.
      NO REVERSE (D
      RANGES OK)
      1. Gearshift Linkage/Cable Misadjusted/Damaged. 1. Repair or replace linkage parts as
      needed.
      2. Park Sprag Sticking. 2. Replace overdrive annulus gear.
      3. Rear Band Misadjusted/Worn. 3. Adjust band; replace.
      4. Valve Body Malfunction. 4. Remove and service valve body. Replace valve body if any valves or valve bores are worn or damaged.
      5. Rear Servo Malfunction. 5. Remove and disassemble transmission. Replace worn/damaged servo parts as necessary.
      6. Direct Clutch in Overdrive Worn 6. Disassemble overdrive. Replace worn or damaged parts.
      7. Front Clutch Burnt. 7. Remove and disassemble transmission. Replace worn, damaged clutch parts as required.
        This is turning into an epidemic!
        WHAT HAVE I STARTED........... i am sorry
