Autobox service and part
  • Autobox service and part
    Hi people! im wanting to service my autobox but not sure what to do or what parts i need, i need some tips on dropping the pan and cleaning/changing strainer, any help would be appreciated. Many thanx, Rob.
    See HERE
      sorry but that is just so funny
      chinny , not a lot needed , just drain it and remove the pan , take off strainer and clean then refit .
      you will only get a small amout of atf out .
      some auto box centers offer a fluid swap for about £80 , well worth it .
      john
      i bust things ,, it a skill i have ,,( need help?)
        Class.
          john
          if i was to do it myself where would i be able to get hold of a gasket for the pan. thanx mate.
            Just use RTV sealant, apply it with a mastic gun.
              Toyota, it probably won't be as expensive as you think.
                I don't think there is a gasket for the auto 'box.
                  not had mine off in a long time , but i think it had a rubber gasket so you should be able to reuse it .or was it bonded on with gasket past ? i cant remember to be honest
                  but as i say i fluid change would be a better option .
                  i only stripped mine after i blew my tourque converter and wanted to make sure i had no bits in the pan .
                  you will only get a few litres out and the rest will be in the box t/c and pipes so you will not change much .
                  john
                    Ah, never looked to be honest. Just assumed there was one as the OP asked where to get it.
                      i have but cant remember , i do recal a chisel and a big hammer for some reson
                        As Vince mentioned, I believe the Toyota method for sealing the pan is actually via RTV sealant.
