I have fluid dripping from front diff area it seems to be atf (gearbox not steering) as the oil level stays fairly constant but transmission fluid is going down (topped it up by a litre in last 4 months). I've looked underneath but cant see where its leaking from its not a vast amount of fluid but I dont want it getting worse any ideas where it could be coming from?
Fluid leak
could be the oil seal at the front of the gearbox in the bellhousing.
mine went a few moths ago i was doing alot of motorway miles and i think that because i was driving it a bit hard that might have been the cause of it going.
if it is it would be a good idea to get the rear crankshaft oil seal changed at the same time while the box is out.
