Hi all,
Nothing came up using the 'search' facility so...
Has anyone fitted a push button start to their Surf?
Instructions are typically vague.
Consists of 4 wires.
1. Wire A to Ground. Even I can get that one right, unlike the following 3...???.
2. Wire B to terminal 15 which is the power path that passes through the ignition switch.
3.Wire C should be connected to terminal 15 on the back of ignition switch.
4.Wire D should be connected to terminal 50 which is the power path from the ignition switch to the starter motor.
Does this make sense to anyone?
Regards
Tony
Regards
Tony
