Little and Large-ish
  • Little and Large-ish
    For those at the Wales run last weekend, this is the truck I was talking about, parked next to a pre-MOT-cleaned Surf. Twelve tons of 'merkin pride.
    first off i dont think i have ever seen you truck so clean!! second off that makes the surf look like a toy!! Awesome
      My truck has never been this clean! The paintwork is shagged!
      Perhaps I'll nick Mark's idea and go with zebra stripes over white
        you must have some desert camo paint at your place!!
          They have - but nobody can find it .........
            here's a better angle on the Surf v Husky size thing.
            And here's what just turned up for me to play with this afternoon. It's on a 4x4 chassis build like a brick shithouse, solid axles and leafs front and rear, auto box, three lockers, crew cab and all that space at the back but no wider than a Surf! PERFECT expedition truck anyone?
                What type of crappy measuring tape are you using then? No wider my bottom.
                  The red one you fool!
                  It's really narrow. Looks odd from the front, but its narrow for a reason so it can squeeze through gaps in trees etc to reach downed planes etc. (It's an airforce rescue fire truck)
                    Isn't a merkin a wig for a fann....er tuppence??
                      Bl00dy 'ell. Twelve tons? That's the same weight as a new London double decker (or 1.5 Routemasters, if your first name is Borris).
                      Andy
                      http://www.surfingafrica.net
                        Well, if you're going to be vague when describing things...
                          i was thinking either tango orange or kawasaki green with black zebra stripes and black exo cage
                          www.overfab.uk
                            Lightweight. Wolfhound is 28 tons
                            However, I expect a bus isn't built from half inch steel plate...
                              I know it's a bit cliched, but it's gotta be orange!
