so i sloved the scraping noise it was the ware indicators on the pads! there was still a fair bit of pad remaining but they were just catching!! so nr side done all ok, then came to offside and one of the pistons on the caliper has seized, will not budge at all is it a case of a new caliper or can they be refurbed?? as a second note one of the rubber bladder things has a hole in it will this cause problems later with mud getting in etc??
1 problem solved and then another!!
Originally posted by hiroler View Postso i sloved the scraping noise it was the ware indicators on the pads! there was still a fair bit of pad remaining but they were just catching!! so nr side done all ok, then came to offside and one of the pistons on the caliper has seized, will not budge at all is it a case of a new caliper or can they be refurbed?? as a second note one of the rubber bladder things has a hole in it will this cause problems later with mud getting in etc??
Yes the hole in the gaiter will be a problem as this will let rubbish in and will eventually cause the piston to seize up.
Might be better off just picking up replacement caliper in the long run
http://www.hiluxsurf.co.uk/forums/sh...ternational%22
If I've got this correct post 2 should have all the info.Gone from 4x4 to 1x2
