Timing Light On Dash
  • Timing Light On Dash
    hi i am new to this forum and to toyota,s, i have just bought a hilux, and the timing light is on, i am getting the belt and tennioners changed,but how do i turn off the t/belt light on the dash off ? anyone know how or do i have to go to the main dealers ? colin
    Hi buddy,I believe there is a small round rubber bung on the lower
    section of the speedo cluster by the trip reset.
    pull it out and use a small thin rod to find the reset inside, would
    posibly reconmend a non metalic item,not just a screw driver .
    Cheers me dears Chris
    GOT NO COWBOYS HERE?
      Chris he has a 3rd gen which is different from the 2nd gens
        How can you tell? Is there a subliminal message in what he said? Or have you used your special powers again?
          Hang on i am getting a transmission from ALPHA CENTAURI
            You can get an ointment for that now Ian
            What have I told you about thinking Erroll
              There's a jumper on the back of the cluster, if it is a 3rd gen. Move it over to the other position.
                i thought it was the same guy who posted in the 3.0l section asking the same question and his was a 3rd gen.Maybe i should look at usernames before answering in future
                  Wheres that Ruddy squirrel when ya need him??????
                    Glad to see you're back on form Gonzo.
                      Out cleaning the skidmarks off my seat !!!
                      Some ####### this morning pulled out right in front of me, thankfully the ABS prevented me from becoming the boot ornament on a bighorn
                      50+ to 20 in less time than it takes for the guy behind to peel his eyeballs off his windscreen !
