had a wee spill with my surf. and took in some water. cut out straight away and i never touched it till i had the glowplugs out. when i was happy the water was away i put everything back together. and it started. rough n reeky but going none the less. anyway next day its running rougher.and reeky reeky. seems better when its warm. dont thnk ive bent conrod. but maybe goosed an injector.? or put timing out? any ideas... 3.0td
Engine Help Req>
thinking bent rod meself,the longer you are running it the more the piston is scrapping the boreOriginally posted by wattyR1 View Posthad a wee spill with my surf. and took in some water. cut out straight away and i never touched it till i had the glowplugs out. when i was happy the water was away i put everything back together. and it started. rough n reeky but going none the less. anyway next day its running rougher.and reeky reeky. seems better when its warm. dont thnk ive bent conrod. but maybe goosed an injector.? or put timing out? any ideas... 3.0td
