new lump
    Sorry mate, got no other communication devices apart from this laptop 'till wednesday.
    What you need to do is seperate the engine and transmission again!
    Drain the transmission fluid.
    Disconnect the wiring plugs, dipstick tube, cable, fluid cooling hoses and linkage from the transmission.
    Remove the inspection plate and the bottom of the bellhousing and remove the six bolts that attatch the torque converter to the driveplate. Remove each one by turning the engine via the crank pulley bolt. This will enable the driveplate to remain on the engine and the torque converter to stay with the transmission. (you may have to prise them apart using a long screwdriver or similar.)
    Now it's up to you how you go about seperating the engine/transmission, either by removing the radiator and disconnecting the engine/transmission mounts and jiggling the two apart, or remove the engine completely.
    Once seperated you need to fit the T/C to the transmission. Slide it onto the shaft untill it 'clunks' into position. it may take a couple of attemps i.e. pull it off, rotate it slightly and then try again, but you can tell when it's fully seated.
    Once you've done that, re-fit the engine/trans back together.
    Hope that helps, good luck.
    diezel weazels right mate your a star im in the middle of doing it as we speak hope all goes well will keep you imformed thanks a bunch for all your help cheers
      Originally posted by Diezel Weazel View Post
      I didn't want to interrupt you n your very sound & well explained advice earlier but Vince you Sir deserve a Medal ...
      Very well done Buddy
      There's always a Payback .... Don't know where n don't know when tho !!!!
      Thanks Jess, you can give it to me at Silverstone.
      No worries, happy to help anytime.
        one more thing when all done how long will it take before i now if its done
          Eh? Je ne comprends pas!
            what i mean is does the oil need to pump through before i can get any gears and how long does it take
              As soon as you select drive or reverse, it should take no longer than a second to engage.
              The torque converter pumps the fluid, the engine spins the outer casing and the transmission is connected to the inner part. The fluid makes them spin together which in turn spins the propshaft/axle.
                oh well i need to try again then still not selecting thought i had it this time try again in morning thanks for your help
                  Eventually get to meet up
                  See ya there
                  Buncefield Burner
                  • #24
                    think i may have damaged pump any ideas where to get one pretty sharpish going to marloes next week (hopefully)
                    • #25
                      i dont think your engine will mate up to the bellhousing if the t/c is not engaged on the gearbox drive , hoping you didnt pull the engine onto the gearbox with the bellhousing bolts if you did you could have done damage to the gearbox
                      • #26
                        i have a gearbox and t/c for this that i have driven
                        • #27
                          how will i know if ive damaged gear box also if so what sort of money would you wantfor your gearbox and t/c
