(think that's what its called) from the back of the radiator .will the fan still cool engine . just think it would make washingthe mud out of the rad a lot easier
if i remove the fan shroud
I think you will still get cooling with the shroud removed, but here's a tip for cleaning the rad.
Someone on here came up with an idea if a length of copper pipe, the end folded to a right angle and squished, the other end attached to the hosepipe.
You should find that it sprays a jet of water to shift the much, and is thin enough to get into the awkward places on the rad.
TrevLook out Eastbourne, the Pandas are coming !
i was kidding lol,most have to do it with the lift anywaysOriginally posted by steve s View Postill keep it on then thanks m8
only works if u actually do it tho eh trev?Originally posted by That Ruddy Squirrel View PostI think you will still get cooling with the shroud removed, but here's a tip for cleaning the rad.
Trev
My local TKmaxx were knocking these out at £20 a shot at the weekend http://www.tools-n-all.co.uk/items/i...LAID=302338069 can go back and see if they got any left if anyone wants to give one a try?
In reply to your original question though, removing the shroud will affect the cooling. The shroud improves the efficiency of the fan, so at low speed or sitting in traffic etc, when the fan is what's drawing air through the rad you may notice it running warmer, or the backup fan kicking in more often. It will affect cooling, but then so will the rad being chock full with mud that's trapped between the rad and shroud aswell.=========
=SOLD UP!=
see i still visit now n then
in the nearly3 years ive had skull ive never had a shroud n ive had no probs with cooling the rad temp just sits there, but then again i think ive got a slightly bigger fan on mine than on a normal 2.4 i think stormy tried to put a shroud on n it wouldnt fit.
im sure stormy or even tonyn will remember the fan i got on mine
i clean mine with steamwasher i lent from work after i left work of corse
should pay there do's
had it a few years now he know when i took it it was not going back
my last rad was down to a brassie shine
so dont go mad on it to clean out the rad like i have in the past
but pit muck dont like to come off thoam not die lex sick its you that cant read mate
ian wot backup fanOriginally posted by nero279 View PostMy local TKmaxx were knocking these out at £20 a shot at the weekend http://www.tools-n-all.co.uk/items/i...LAID=302338069 can go back and see if they got any left if anyone wants to give one a try?
