test run
    Originally posted by steve s View Post
    thank you but the car sounds like a pig farting through a trumpet when the turbo kicks in
    like an isuzu ? lol
      yes thats it
        think we could use this one for caption time
          The missus is going to kill me for this
            After Val decides she's going to learn to drive, Dave booby traps one side step just incase she decides to try and take the surf for a spin.
            =SOLD UP!=
              Has anyone got a few tie-wraps to spare please?
                Originally posted by mud skipper View Post
                whats your radio reception like NOW
                Can I ask what makes you ask that question ? Before I rip my stereo out
                  Looks good.
                  Only thing I'd ask is the bit circled in the attached picture, did you straighten it out?
                  • #24
                    Looks good.
                    er no
                    • #25
                      er no
                      That may eventually fill with water/crud and as it's a low point, it'll block the air flow.
                      Everything should run down towards the air filter box, there's usually a drain in there.
                      • #26
                        mmmm see what you mean i was going to drill a hole in the bend and fit a length of pipe (drain pipe ) and when off roading i would fit a bung in the end
                        • #27
                          If you can, I'd take the wing off and re-position it all to do away with the low point.
                          • #28
                            will look in to that thanks
                            • #29
                              Errr...I was thinking of doing the "snorkel" thing......but I read somewhere else on here that you should also block up the drain in the bottom of the airbox, otherwise the water would just come in through that....
                              I'm still undecided on a snorkel......it may have to be homemade as I can't afford a Safari or similar.....and I don't know whether I can take a saw to the wing.
                              .......although I think I have found a 3rd gen "breaker"
                              • #30
                                You need some kind of drain somewhere, or something to keep moisture out.
                                I've not looked, but the drains inside filter housings tend to be on the dirty side of the filter and are generally one way valve affairs.
                                As I said, not looked, so am up for correction.
