Hi Lift Jacks
  • Hi Lift Jacks
    Are there any mounting points on the surf that you could use a Hi lift jack on .....whithout trashing the body work?
    Mark
    You would need to fit sliders from the chassis or mod the bumpers.
    Brian
      Unlike some vehicles there are no specfic built in jacking points on the Surf. Most people will jack on the rear axle casing or under the front wishbones or frame rails, so you are best using a jack that has some sort of "cup" on the top to locate on the appropriate points, for safety's sake. And always use axle stands as well once it's jacked up.
      Mike G
        You can buy a jack mate that lifts from the wheel itself. Its what I use my hi-lift on and it does work but not perfectly. Although it seems odd its great for changing a wheel as you can lift it quickly, stick an axle stand underneath, remove the jack and change the wheel. Good for lifted trucks too that are too high for standard jacks.
        Bear in mind if it slips off the axle stand when you have no wheel on there is no way of raising the surf again without a normal jack
        also I treat my Hi-Lift as if its trying to kill me at all times which seems to be the only healthy way to use them.
        I did get a locating point fitted as part of my winch tray but as its central its not much use for much other than breaking the suction when stuck in really deep mud.
          Had that feeling,thanks
          Thanks for that, I always use stands and paranoia makes me chock it up with blocks as well....you only get to drop a truck on yourself once!!
          I use them at work for awkward jobs and have a healthy respect for them...no end of times they slip or twist out if the load moves unexpectedly!!
            Hi
            Had some jacking points fabricated and then welded onto my ARB bumper and rear crossmember for the trailer hitch. Make life a pleaseure:
            http://www.elphick-pooley.co.uk/htm/....htm#jackpoint
            @africa4x4cafe
            [url]www.africa4x4cafe.com[/url]
              http://forums.bauchan.org/portal/downloads.php?dcid=13
              4 inches too long as for a 1st gen
                Mark
                No. You would have to fit aftermarket bumpers, rock-sliders or some form of chassis extension. Apart from that wheel-bracket accessory already mentioned.
                chris
                oh, and your tow bar if it`s flat or with a hitch accessory.
                Powered by Toyota!
                  You don't want to be in the way of an uncontrolled unload when your fully loaded, 3tonne, surf is behind that jack handle!
                  Not so usefull in the UK when you are on tar most of the time but ###### usefull in Africa!
                  @africa4x4cafe
