Originally posted by Maverick
View Post
don't do that, in a sense i'm playing devils advocate, I do believe most of what i'm saying though. The point i'm trying to get across is exactly what you picked up though.The biggest single component that's going to help you out here is the condition (and quality) of the actual suspension components, they're what's going to keep the tyres on the ground and in line under the truck (hopefully), next the loading of the truck whether everythings stowed securely etc, or if there's suddenly going to be 4 bags of sand shifting about in the back of the truck, or a load move on the roof rack, then you're tyres, i.e) your contact point with the road,etc...
....and so on....
...somewhere way down the list is whether you've got ARBs fitted or not.
The other point to make is that a truck with the ARBs removed is allmost certainly going to have other mods too. IE, quite possibly suspension, tyres, body lift
Please
on 2nd gen fitted procomps , milners stiffer springs and spring spacers noticed when i took arbs off the truck weighed less
Leave a comment:
