oil change
  • oil change
    Looking to do some basic maint on a SSR X ive just bought can any one assist me in the following:
    What spec of oil should I use?
    How much does a 2.4 take?
    Where is the drain plug?
    How hard is a thermostat to fit?
    How much and what type of coolant should I use?
    Regards
    Tim
    [QUOTE=Tim]Looking to do some basic maint on a SSR X ive just bought can any one assist me in the following:
    any diesel oil is ok, regular oil change is more important
    around 7 litres
    drain plug is on the sump, oil filter is accessed through the front wheel arch, drivers side, take off the wheel and you will see the panel that comes off
    thermostat is easy to change, get a genuine toyota one
    not sure of the top of my head how much it holds, around 33% to 50% coolant/antifreeze is ok, bluecol is good, remember to get rid of the airlock after you have refilled it,
    burping the cooling system can be found on the main site under technical
    [size=5][/size]
      Oil Change
      Ian
      Thanks very much for the advice, Ive ordered a thermostat from milner offroad, is this likely to be a Toyota part?
      Tim
        Originally posted by Tim
        Ian
        Tim
        milners service items are not genuine toyota, if you have already orderd it i would use it
        [size=5][/size]
