4wd question
    mine is (reasonably) similair vince. i have one vacumn hose "fooling" the vsv into thinking its in 4wd.When i press the button into 4wd it engages the collar forward and sends drive to the other drive shaft.When i disengage the 4wd,the vsv loses all power (my mod) and the front prop stops turning..and the manual hubs are a graet boon as well...make it bulletproff
    Excellent!
    I'm going to be ordering an Aussie locker for my rear diff soon, then manual hubs. Gonna be doing some mudpluggin' this year.
      I'm doing this mod to mine when I can get the truck into the workshop....
      http://www.4x4wire.com/toyota/tech/add/
      I'm being a bit thick probably but I'm not sure how that works. If he's locked the ADD, isn't the truck in 4WD all the time? Or is there something happens in the transfer box too?
        It just locks both front CV shafts to the diff eliminating any possible failure of the vacuum system. You do get more driveline drag, but that too can be eliminated by fitting manual hubs.
        The actuator on the transfer box engages the front axle. (the one Mudsurfer had problems with)
        http://toyotasurf.asn.au/techsite/add.htm
          Got it!
          Yeah, obvious when you think - which I didn't
            Got it!
            Nowt new there then.
            Checked the bulb. Appears fine. Swapped it for the hard/soft bulb as a precation though. Should have known it wouldn't be that simple. Must admit though, I am having Ian like thoughts now. Seems prime time for L.E.D'ing it. Trying to resist........
            p.s: Vince, I have no idea what you mean over the disassembly bit.
              Well, something is definitely buggered. No 4wd, so gonna have to start backtracing for the problem.
                Have you checked to see the Ginger dildo is correctly connecting to the other bit?!
                Ginger dildos can always be a problem if there not properly looked after!
                I'd check the ginger dildo mate!!
                  i think the ginger dildo thing is now becoming insulting.
                  it's not matt's fault he's ginger (genetics), or a tight ar5e (geography) or a #### (environment - possibly). but that's what he is so let's stick to the facts. i don't recall him being proven to be a sexual implement, that would make him useful!
                  • #24
                    cause wod knows
                    • #25
                      Matey, I'm offended.
                      How could you honestly suggest that I might actually be useful?
                      • #26
                        Would that be the grey one then?
                        • #27
                          cause wod knows
                          Im the rubber expert right?!?
                          I know all things about all things rubber!!
                          • #28
                            Except for how to burn it.
                            • #29
                              sorry bud - i meant no offense, i take it back - you are of course completely useless!!!
                              • #30
                                lololololololol
                                Brian
