diff breathers
  • diff breathers
    hi all i want to fit diff breathers to my surf can somone tell me exactly what i need and were to get bits from. thanks steve
    mini fuel filter from halfords or other motor factors £3 (x2 or alternatively a Tee piece to join the pipes before the filter)
    1/8 BSP to push fit pipe fittings
    appropriate pipe to connect the bits together
    selection of cable ties to fix the pipe up in appropriate positions.
    =SOLD UP!=
      oh and either try contacting gupster for a full kit, buying a landrover kit off ebay (they use the same fittings IIRC), or look up the hose and bearing company, denmark road, ashford. If they got it all in i can pick it up for friday and bring it saturday. They're about 500 yards from home for me.
      =SOLD UP!=
        i don't think you'll find gupster about on the forum now after what went on at hpoc
          last i heard he was still selling them, i think that was after the bust up over there, but to be honest i lost interest in all that was going on with them a long time ago
          =SOLD UP!=
            hi ian just looked on the h&b site couldnt see wot i wanted. thanks very much for the offer ill try e/bay see you sat
              http://www.hiluxsurf.co.uk/forums/sh...diff+breathers
              try that dude
                thanks for your help guy s but i havent got a clue were id get the bits from around here. i can write a list of bits from you all but were were do i get the bits . can i get a kit from some were? and should i change the diff oil when fitting the breathers
                  you can get the diff unions direct from toyota and the pipe you can get from b&q or somewhere like that and the little filter from any motor factors
                    get the screwins from thses people
                    Unit 24
                    Castle View Business Centre
                    Rochester
                    ME1 1PB (Road Map)
                    Kent
                    Tel: 01634 832211
                    get the filter from here
                    Block 3,Unit 4,
                    Vestry Trading Estate,Otford Rd,
                    Sevenoaks,
                    Kent
                    TN14 5EL
                    Tel: 01732 464546
                    get the pipeing from wicks
                    Unit 1, Foster Rd, Ashford Business Park, Sevington, Ashford, Kent TN24 0SH
                    Tel: 01233 502088
                    find ya loads if ya tell me what area ya want
                      can use these - http://cgi.ebay.co.uk/2-1-4-HOSE-BOR...ayphotohosting
                      if there's enough clearance on the front diff to get them in between the diff and the sump.
                      the 90 degree swivel ones are better on the front though. doesn't make much odds if it's 90 or straight on the back though. Pretty sure i have one fitting and a little pipe here anyway. Might have a 2nd fitting somewhere. I'll bring them sat.
                      =SOLD UP!=
                        thanks alot ian see you sat
