3rd Gen Buzzer " how To Disconnect"
  • #16
    Can anyone point me in the right direction for the same issue on a '95 Gen 2. Key ignition buzzer is v annoying so would like to disconnect it.
    Cheers.
    • #17
      Cheers.
      I think you need to look at the link posted by "Ava_Banana". Thanks for bringing the thread back up, I hate the buzzer but I disconnected the switch in the door and the loss of the "headlight's on" buzzer caused a bit of a fight between me and the missus when she got stuck with a flat battery one day!!
      • #18
        I often leave the driver's door open when hooking up a trailer and the bong bong is enough to drive you insane.
        • #19
          I'm guessing there is no way of picking the right wires without a voltmeter? Can't see enough detail in the photos.
          • #20
            Its as clear as day, there is only one pink & black wire coming from that plug.
            Are you looking in the right place?
            • #21
              Are they black/pink on all 1995 SSRX's?
              • #22
                If you look back at the thread the first image is my 1996 3rd gen wiring & the second image is ava's early 3rd gen but with second gen wiring.
                As far as im aware there are only the two types of loom.
                • #23
                  Not quite si, mine has similar wiring to yours in that it is pink/black to be cut.
                  2nd gens are harder to get too (see pic in link posted previously) and wire to snip is WHITE AND BLACK stripe.
                  • #24
                    Ahhh, i stand corrected mate.
                    Thanks for clearing that up.
