Excuse me for butting in, but, having had quite a bit to do with this sort of thing, you also need to consider the leverage the winch will impose on the front of the chassis. If you winch cable is one ft above the centre of the chassis rails it will impose a load of (and yes, I know this is very approximate) 8900 lb ft for a 4 ton winch, this equals one very bent chassis on a good pull. Hence a good winch mount will spread the load along a large area.
Rod
Rod
