Milners
  • Milners
    Well i have found out what is causing the dodgy steering on my truck, it seems that the lower near side ball joint is fubar. I am right in thinking that i should not be able to lift the break disk up and down i understand that there is a max of 5mm of play, if this is right mine moves 10-15mm. Now my question is do milners replace stuff if it fails within the 1st year? Both ball joints were replaced by Tony N about 9 months ago.
    SWIFT AND BOLD
    Holy feck...
    Thats pretty bad!!
    I'd give them a call mate. But i'd go roughtrax for the new parts. Milners will be the same old junk an last 9 months again!!
      thanks Rod i am right in tinking that there should be no play at all in them, I think milners and roughtrax nox do the same part.
      SWIFT AND BOLD
        ROUGHTRAX always use Superior Quality parts to Milners especially IDLER ARMS & BEARINGS
          Milners used to state all parts guarunteed for 12 Months
            some milners parts are genuine toyota , i think they had a g in the part number, the trouble is since they changed the website you cannnot see the part number
              I'd expect no play in the set up mate.
              anything at all would be detrimental to any aspect of steering and suspension.
              Get on the phone to milners monday morning and talk over refund for premature failure etc.
              Then spend your money at roughtrax.
              You do pay a little more but its always spot on... milners seem a bit hit and miss.
                I have the Milners parts and price list on my pc, if you send me an email address i'll sent it to you(free of charge) and no play in it at all.
                The Milners web site may have changed but the part No.s should still be ok
                Paul
                  Thanks guys. I will let you know what they say
                  SWIFT AND BOLD
                    Ok guys spoke to milners today and they are replacing the lower ball joint foc no hassle at all. So thats sorted.
                    SWIFT AND BOLD
