Bump
Tech Weekend
Originally posted by Mitsy View PostCool but what about any gaskets ect.
It depends on whats left on the engine .........is the exhaust manifold still on ?? have we a pic of the engine to look at , or even better ask the donor' You've arrived on a rather special night. It's one of the master's affairs.'
Originally posted by BioHazard View PostIt depends on whats left on the engine .........is the exhaust manifold still on ?? have we a pic of the engine to look at , or even better ask the donormonstercreations.org.uk
The turbo off of mitsy's should swap .......
what year is the engine out off...... is it a 2lt
http://www.toyodiy.com/parts/p_J_199...KMGX_1701.htmlLast edited by BioHazard; 21 February 2009, 23:26.' You've arrived on a rather special night. It's one of the master's affairs.'
good all the inlet side is there .. mitsy you will need exhaust manifold gaskets , studs. cam belt might be a good idea as well , check with stein and bushwhacker for other items
also give your exhaust manifold a good dose of wd40' You've arrived on a rather special night. It's one of the master's affairs.'
